How To: Add Factory Power Doors
Old 10-01-2008
wvcat's Avatar
This is a how to to add power doors to your truck. Power windows, door locks and mirrors. I am not going to cover adding the individual components here because I added complete power doors to a project truck. In my case I am working with a 2000 ranger xl 4wd but most rangers should be similar with the exception of different color wires on different years. Before you even start consider the following. If you hook something up wrong you could damage the computer components in your truck and therefore this is a do at your own risk type mod. Basically you will be adding a wiring harness, 5 relays, hooking in to the fuse box for 3 seperate power supplies and adding wires to the gem module. When complete the system will work as if factory installed and will even include the auto down function on the drivers door window as well as the accessory delay relay that allows you to roll the windows up after you have removed the keys. (this cancels when you open your door) It would be possible to make your own harness and install it without removing the dash however I removed the dash and used a factory donor harness that had power doors from a 2wd truck. If you could economically find a factory harness swaping it in would save you some work. I had no luck finding one. Ok here goes.
I am not going to cover removing the dash but here is the factory dash removed without any modifications to the harness.
I removed the factory harness from the dash. Note the door plug near the fuse box with only 4 wires on the drivers side.
After dismantling the donor harness here is what is required for the power doors.
Here's the difference between a power door plug and a manual door plug. Note the wires on the power door plug donor I have folded over, these are already existing in your truck.
The first step is to remove the wires one by one from the donor harness plug and istall them in the corect position in your factory harness plug. If you look at the picture above you will see a red piece of plastic inside the plug, this has to be removed and then use a tiny screwdriver or scribe to push the tab back and remove the wire. This is what a removed wire looks like.
After you transfer all the wires this is what it should look like. Don't forget to reinstall the red plastic lock into the plug. Note the 4 factory wires and the 9 you just added.
I just taped the new harness to the existing harness.
You will be required to add this relay box to the center of the dash with 3 mini relays and then 2 other relays. Note the wires going over the black relay box, they go to the gem. The all unlock relay is on the bottom right (note the black relay with red in the plug.
Unfortunatley this is all the pictures I can find so I'm not sure if I have any more but this will get you the basic idea and concept of how to do it. Between these pics and the following wiring diagrams you will have all the required information on how to do it. A big thank you goes out to Ramsey Leonard for providing me with the wiring diagrams.
You will need a donor harness with relays or...
the factory wiring pins for the door plugs-approx 20 that snap in
the factory wiring pins for the gem module-approx 5 that snap in
the factory wiring pins for the fuse box-approx 3 that snap in
the factory relay box behind the dash with relays and wiring ends that snap in
the 2 relays for the auto down and accessory delay with plugs and wires
misc wiring supplies such as butt connectors, tape, strippers, and crimpers as well as alot of time to have your truck down, its not really an afternoon job.
Good Luck
John
highway101 (12-05-2020)
Old 01-23-2013
rangerowner's Avatar
Just finished this mod and if u had a gem with no power group u will have to get a gem with power group otherwise power to the accessory relay for windows and OTD WILL not work. gems before 01 should be plug and play however. Just get gem from same year and with either RABS or
4WABS as appropriate for vehicle. I have all diagrams for all year rangers.
Old 02-08-2013
bump
Old 02-18-2013
In addition to the above mod for power i have added remote keyless entry factory installed. Again I wnat to reiterate that i have successfully cmpleted this mod and know first hand the ups and downs of it. If anyone has any questions regarding this mod feel free to ask. And thanx goes to author of this post for getting me started.
Old 03-09-2013
bump
Old 06-03-2021
kmbkk's Avatar
Bringing this one way back from the dead...
I have an 03 B2300 base. My doors are dinged up so I was looking for replacement doors. As luck would have it I found an 01 XLT (extended cab), same color and the doors are in great shape. So My thought was to replace the doors. The owner said they were power doors so this got me interested in doing the manual to power doors swap. However, it's not plug and play (obviously) but doesn't seem to daunting a task (based on this thread). One difference from my potential swap is I can probably get the dash from the donor truck (guy told me everything is available and in great shape). So rather than splicing in the required wiring harness, could I just swap the dashes instead? I'm still new to the Ranger/B-Series trucks, so I'm not 100% sure it would be plug and play for the dash swap. If not I can just go with this thread's swap. TIA!
TommyC
09-09-2015 12:34 AM
Downey
03-14-2014 08:38 PM
ShadowRanger08
Fabrication & Tool Tech
37
04-21-2012 01:15 PM
04blackedge
12-29-2007 09:23 AM
DaneTrain
09-26-2006 04:58 PM
Quick Reply: How To: Add Factory Power Doors
