Torsion Bar Cranking
Old Dec 11, 2008
Great post!
Old Dec 11, 2008
Jimmeh's Avatar
Thanks D. This helps a lot for us suspension noobs.
Old Mar 14, 2009
03edge's Avatar
awesome this clears up quite a bit!
Old Mar 31, 2009
DangerRangerDan99's Avatar
Thanks for the explaination. I have absolutely NO knowledge or experience with torsion bars, but this at least gave me a clue as to what I am working with. Great Post!
Old Mar 31, 2009
Goodysgotacuda's Avatar
Thats cool, but i've checked my alignment on two separate machines and they were in spec. with the tbar cranking. not saying the upper ball joints wont wear faster or anything. but the specs were there
Old Apr 1, 2009
IN2 FX4's Avatar
After I cranked my T-bars the camber on both sides were right in the middle of the specs. The toe was off a little. I suspect the camber was off before I cranked it.
I only cranked it 1.5" and the ride height was still within the Ford specs for a new suspension. It was right at the max but not over. Ford also has specs for used suspension and it was above that range.
After 40k miles of so I checked the ride height again and it had sagged a little. I cranked it a little more to keep it at the maximum new ride height. At over 95,000 miles now, the front suspension is showing no signs of problems. I am due for a check on the ride height but will wait until I am also ready for a front end alignment. Except for a shock replacement, I don't think any changes should be made to the front suspension without an alignment check.
Old Apr 1, 2009
Prerunner-Ranger's Avatar
Level I Supporter
Ball joints will wear out quick and you will have uneven tire wear as well.
Old Apr 1, 2009
IN2 FX4's Avatar
What do you call quick? 95K miles seems like a lot to me and the ball joints don't indicate any problems. My original tires (BFG AT) lasted over 65K miles and had even wear. The current tires (Michelin LTX M/S) are wearing very little and show no signs of uneven wear. I expect them to last over 80k miles.
Old Apr 6, 2009
Dumpedmk3's Avatar
I got 10k out of a set of ltx's.
Nice post.
Old Apr 7, 2009
Level I Supporter
What happened to D.?
Old Apr 7, 2009
IN2 FX4's Avatar
Nice post.
I am approaching 30K with my LTX M/S tires and they show very little wear.
Old Apr 12, 2009
kymudder08's Avatar
at my work all we use on our e250 vans and f350 2wd 1tons is the ltx's. we drive about 2-300 miles a day and the most we got out of a set was 115k miles. not offroad vehicles or nothing but it still says alot... and which are the actual torsion bars. before i get my lift installed i wanna crank them myself bc the shop wants 50 bux just to crank em...
Old May 2, 2009
jckb4000's Avatar
he got a week long ban , and then told rf to go to hell,
to bad because i always looked for his posts , his truck is original to say the least and he was really good with the tech aspect of things.
Old Sep 4, 2009
broke's Avatar
i have to agree. i cranked mine and couldn't get a good alignment to save my life. after a set of tires and ball joints all the way around, i had to put them back to norm.
good post though
Old Sep 4, 2009
Hanks Rangers's Avatar
posted before i looked
Last edited by Hanks Rangers; Sep 30, 2009 at 10:10 PM. Reason: mental malfunction
Old Sep 28, 2009
This sticky has wrong info in it, if you crank your torsion bars it will pull the top of the wheels in, not push them out. So instead of it adding positive camber, it is subtracting it or adding negative camber. Either way, if you crank them enough, just get an alignment after if your camber is ****ty...
Old Sep 28, 2009
Vince30's Avatar
Sry sir but you are wrong.
Old Sep 28, 2009
Prove me wrong please
Old Sep 28, 2009
Red_Ak_Ranger's Avatar
I can think of multiple people, inlcuding myself, who have never had issues with camber and have cranked tbars. My tires wear fine also.
Old Sep 28, 2009
lol leave it to Aaron to miss the whole point. Im just saying that d was wrong saying when you crank it adds positive camber, it adds negative.
Old Sep 28, 2009
Woods-Rider's Avatar
x2. adds negative
Old Sep 28, 2009
Vince30's Avatar
I'm not exactly sure how to explain it without pictures so how about you prove me wrong.
Old Sep 28, 2009
Because I don't care enough to prove someone wrong who doesn't even have a ranger?
Old Sep 28, 2009
Vince30's Avatar
Haha dang you are a cleaver one.
Not like a have to worry about that stuff anywase with my solid axle 3 link.
