How To: Eliminate Door Dinger on 04+
Old Dec 27, 2008
I got tired of listening to that freaking ding everytime I opened my door when I was modding and had the radio on so I set off on finding a way to turn it off. This will totally eliminate the door dinger when the key is in the ignition, I choose to put it on a switch so I can turn it on and off whenever I want.
I got this mod off of www.generation-edge.info but I figured it would help this site as well. All the pictures are mine though, credit to Diggr for doing the research originally.
Tools needed:
Torx 15
8mm socket
Wire cutters/strippers
SPST switch (optional)
and your connectors of choice
You'll need to remove the under the dash panel, here is Ford's manual instructions on how to do it with my own pics under that. The cover is held on with 4 Torx screws. 2 behind the parking brake handle and then 2 on both bottom corners. The metal panel behind that is help on by 5 8mm bolts.
Then you'll see the metal cover
Here is with both panels removed, the wire we will be cutting is in the yellow insulation.
This is the connector the wire is coming from, we are cutting the black/pink wire.
Now make sure to cover both bare ends of the wire, I chose to use female ends so I can add a switch.
And the switch I used, just one I had in my garage.
And my new toolbox, I love it
Any questions or if I left something out feel free to ask!
Old Dec 28, 2008
Good write up, Trent.
For anyone interested, here's a variation on the same idea. It's a self resetting, pushbutton dinger disabler:
2001~2003:
https://www.ranger-forums.com/forum2...84&postcount=1
2004~2006:
https://www.ranger-forums.com/forum2...8&postcount=22
Old Jul 5, 2012
rangersport07's Avatar
tried this on my 2007 sport supercab..... didn't work. i double checked that i had the right wire.
So to sovle the dinnger problem, i popped the actual buzzer off the cluster pcb..... always silent now.
Old Jul 5, 2012
zx6rrdan's Avatar
When I looked at doing auto windows the wiring color changed for 2007+. Might also be different for this
Old Jul 6, 2012
vista4.0's Avatar
just to clarify. 04-06 and 07+ have different wiring. this mod is only good for 04-06
Old Jul 6, 2012
yeah I do believe this very same black/pink wire has something to do with the dome light in my 07, because I now have no dome light... gotta connect it back together now..
Old Aug 11, 2013
mudlight09's Avatar
I have a 95 and i the wire for my dinger runs to my door with the speaker wires. I cut the wire there and the problem was solved for about a week. But now everytime i crank the truck i hear a new ding. it does 5 sets of 5 beeps when u crank it and every 40 minutes that the truck is running. Does anybody know whats going on?
Old Aug 17, 2013
The 5x5 beep is the backup for the Supplemental Restraint System (airbag) lamp. It means that the SRS lamp circuit has higher than expected resistance - usually due to a burned out or missing bulb.
Fx4wannabe01
53
May 11, 2018 06:11 PM
Needforspeed3685
Jan 26, 2007 11:38 AM
dcantato
May 29, 2006 01:32 PM
mjktg99
May 27, 2006 06:42 AM
Zero
Sep 28, 2004 10:35 AM
