ANOTHER BL question..lol
Old Jan 4, 2009
hozII's Avatar
Icon7 ANOTHER BL question..lol
getting ready to do the 3" PA BL on my 06 auto. YES i have searched threads on this. Found out about the infamous A/C line and e-brake cable. I was just wandering if there was anything else like wires or something along that line i need to be mindful of. I should be getting the kit in the mail this week thus for i have not seen the installation instructions yet either. Also like to request some pics of 3" BL on 33's. I've done the t-bar crank and rear shackles already was just wandering what im lookin forward to here as far as what they'll look like. NO i don't wanna run 35's right now..lol!! Maybe later though!!
Old Jan 4, 2009
robert99ranger's Avatar
This help any? It on a 98 but I dont think there is much of a difference.
http://therangerstation.com/tech_lib..._BodyLift.html
Old Jan 4, 2009
hozII's Avatar
AHH. Yes thanks. total brain fart on my end. I'm a memeber over there too. NO offense to that site because it is a good one but i prefer it here, that's why i didn't think of it..LOL!!!
Old Jan 4, 2009
Are you asking for the install instructions? I can email them to you if you want, just let me know what your email is.
Old Jan 4, 2009
My05edge's Avatar
remove the clip from the firewall holding the shift cable, i didnt and ended up breaking the shift linkage. just follow the directions and dont skip around
Old Jan 4, 2009
Sea-Bass's Avatar
Hell yeah, 35's would look better...I know a guy who has some...
Old Jan 4, 2009
hozII's Avatar
LMAO!!! I was waitin on you to chime in!!! Oh on the filler neck extension. Anything special or just some rubber hose from lowes/home depot? Hey Chris next weekend still lookin good on the wheels?
Old Jan 4, 2009
hozII's Avatar
NAW. Just basic general info. just trying to get preped and still waiting on BL to come in mail.
Old Jan 4, 2009
Sea-Bass's Avatar
Yeah, I'm going to order my new wheels and tires in the morning...I hope
Old Jan 4, 2009
I got mine from Lowe's, just a piece of metal pipe and two hose clamps.
Old Jan 4, 2009
Ace's Avatar
Ace
well here is from when my BL was being installed and i have 33's
Old Jan 4, 2009
What is that a picture of?
Old Jan 4, 2009
Ace's Avatar
Ace
a silver truck with black tires pic also includes a blue jack a cb antenna......
what do you mean what is it a pic of?
Old Jan 5, 2009
Oh I forgot he asked for a pic of the 33s lol, I thought you were showing something specific lol. Nevermindddd
Old Jan 5, 2009
Originally Posted by Ace
wow, thats a cool body lift!!
Old Jan 5, 2009
^^HAHA.
I'm unsure what the summit instructions include, but the PA ones are actually some of the best instructions i've seen. They pretty much cover all the little things that you must watch out for. The kit also includes every little piece you'll need...including those filler neck extentions in two different sizes.
Idk if you've got a hitch or not, but hitch install could be a pain if your hitch mounts to the side of frame....you'll have your bumper and the hitch bolted on using the same bolts and the same holes in the frame...definately a two person job at least. The rear bumper brackets will need to be widened in order to fit the hitch between the frame and the bumper brackets. Some put the bumper brackets in a vice and beat them out. Others(like me) choose to space them further apart on the bumper using either washers or a spacer plate.
Positive battery cable might be sorta tight even after unbolting the bracket from the engine block. So to cure that issue, I broke the push in holder thingy that holds the harness to the back of the a/c condensor and that gave me the proper amount of slack.
The E-brake cable i did nothing with...didn't use the bracket in the kit as i was able to get away with it in all the bodylifts i've installed.
If you can get away without using the ground strap extentions, go ahead and dont use them. On mine, the frame extention on the passenger side i didn't need theextention. Same goes with the engine bay drop...i just relocation the top of the strap to the hole or stud below the hole PA wants you to use.
IF the front bumper brackets studs decide to break loose on you...you can easily use 1/2" bolts instead. On Marie's truck, I used 1/2 x 1.50 allen head bolts for a nice clean look when looking at the bumper hole since her front bumper brackets didn't have the studs on them.
Rear bumper brackets in the instructions say to use the outrigger bumper supports(the diagonal ones). On 3 bodylifts, i have been unable to make those darn diagonal brackets work with the PA brackets. Oh...get a set of Torx sockets...you'll need 'em.
I use a 3ton harbor freight jack and a 12x12 block of wood to jack the body up. The bed I just use my muscles and pick the bed up and put in the block. Proper torque on the bolts is approx 83 ft/lbs i believe. Get them all torqued down properly and the bodylines should line up perfect between the bed and the cab.
Myself and trent have the PA instructions on our comps...so we could shoot it your way. Talking about the 01-05(and up) kit's instructions.
Old Jan 5, 2009
Shane nailed everything on the head, of course. This is a folder of pics that Shane sent me, helps a lot when your curious about how to mount certain things. I didn't use a e-brake cable extension or any ground extensions, didn't need too. Hitch is a pain in the ***, I had to bench press it in place while laying on my back and then use my head and arm to hold it in place while I put a bolt in, then it was so tight fit I had to use my floor jack to move the hitch in to place so I could get the bolts through. Here's the folder:
http://s188.photobucket.com/albums/z...%20Components/
Old Jan 5, 2009
OHHHHHHHH YEAHHHHH...
gotta add this...
Get yourself the fan removal tools....you'll need 'em. Take the fan off and the shroud. Pay very close attention to the radiator while jacking the cab up. Get the radiator off the mounts BEFORE jacking the cab up, and make sure to periodically check the rad and make sure it's clear of the mounts of the core support. The lower rad drop brackets...MIGHT need to be ' V'd '....meaning....put them in a vice, and make a slight 'V' of the long sides. This is to make sure they clear the coresupport. You COULD get away w/o removing either fan or shround...but i've been unsuccessful at doing this. I don't suggest it. Risk destroying a fan shroud should you try(sorry marie!!) and possibly wedge the rad sideways and destroy a rad mount on the core support....so keep your eyes open should you decide to not remove the fan or shroud. So...get your tools and DONT LOSE THEM!! lol.
I also suggest painting all your parts black prior to the install. This is a step i wish i did before my install, and i did do this prior to marie's install. Rad drops, ground ext's, bumper brackets, etc....
oh...and shoot....who doesn't like pics....
https://www.ranger-forums.com/forum2...ad.php?t=76117
Old Jan 5, 2009
x2 on making sure the rad is off the mounts, I failed to do this and I had to jack the cab back up and take all the blocks out, move the rad off the mounts and then put all the blocks back in. PAIN IN THE ***
Old Jan 5, 2009
hozII's Avatar
Awsome info guy's excatly what i was looking for in getting preped for this. I plan on taking a weekend to it, starting on a friday night. I'll get pics up and posted when i get it going. once again MANY thanks!!
Old Mar 1, 2009
Dumpedmk3's Avatar
i must comment on this thread to make it easier to find later....
Old Mar 1, 2009
monkeysteeler12's Avatar
^^same^^
Old Mar 1, 2009
Ace's Avatar
Ace
Originally Posted by monkeysteeler12
^^same^^
He's done lifting it lol
Old Mar 1, 2009
how about subscribing to it?? or maybe bookmark it???
EMB1230
Jun 24, 2010 12:53 PM
Tys 4x4 FTW
21
Feb 8, 2010 08:09 AM
hozII
Wheels & Tires Semi-Tech
44
Oct 25, 2009 08:53 PM
FordGuy302
Apr 10, 2009 07:53 AM
Sixt9coug
Mar 28, 2009 03:53 PM
