Fuel filter disconnect trick.
Old 04-27-2009
IN2 FX4's Avatar
I have seen a lot of posts regarding difficulty in disconnecting the fuel lines from the filter. This weekend I replaced my fuel filter and discovered an easy way to disconnect them. At least it works well on my 02.
If you look at the fitting on the fuel line you should find a tab or long button looking device on one side that is flush with the outer diameter of the fitting. Mine were either orange or green depending on which line it was. I found if I pressed in on this tab/button with my thumb nail, it would easily release the line fitting from the filter. You could use a screw driver also but I found it easier to wrap one hand around the fitting and use my thumb nail to push the tab/button in while holding the filter with the other hand to pull them apart.
I did use a tool to disconnect one of them but was having trouble getting the larger line to disconnect with the tool. I decided to try pushing in on that tab/button and it practically fell apart. I am glad I like to experiment because that job will be a lot easier now.
Old 04-27-2009
MemphisSenior's Avatar
Thanks Gary. Good tip. I'll try it next time I change mine.
Old 04-27-2009
Pushing in that green and orange with my fingernail is how i do mine.
On '01+ trucks, you dont need any special tooling to disconnect the fuel lines from the filter.
Old 04-27-2009
Thats how I did mine as well, super easy.
Old 04-27-2009
robert99ranger's Avatar
So I need a special tool on my 99 then?
Old 04-27-2009
Blhde's Avatar
Yup.
It helps to push the line onto the filter more then installing the tool, while you still try and push it onto the filter.
You may need to wiggle the line a bit. It should slide off easily if you have released the lock.
Make sure there is no pressure on the system. It will go everywhere. Being that your face is right there. Its not a good time.
Old 04-27-2009
I dont remember how i took mine apart on my 94 but i didnt need a special tool to get it off i just got the clips off and then slid the lines off
Old 04-27-2009
redranger4.0's Avatar
my 2000 had plastic clips you pull out and the filter comes out no special tool needed. Up by the motor there is a spring style fiting that needed a tool though.
Old 04-27-2009
chevyslayer925's Avatar
i need to do this to mine yet. . .ive been putting it off for some time now.
Old 04-28-2009
99_NWRanger's Avatar
Yeah, I haven't changed my fuel filter out the entire time I've had my truck! I think I should do it soon! hah
iplayloudly
05-02-2012 03:10 PM
Bobby
12-01-2011 06:23 PM
ranger99ct
07-30-2011 07:16 AM
Takeda
07-08-2010 04:34 PM
lostguitarist
01-08-2009 04:38 PM
Quick Reply: Fuel filter disconnect trick.
