OLD - Engine & Drivetrain Ford Ranger engine and drivetrain parts, i.e. radiators, driveshafts, knuckles, brakes.
For Sale: Manual t-case linkage adapter--OR
Old 03-23-2010
Dangerranger01's Avatar
Up for grabs is a custom bracket to adapt manual t-case linkage without having to source the ultra rare and expensive FX4 LII tailhousing, when upgrading to a manual t-case.
It is designed and built off a LII tailhousing, so you know you're getting a quality part.
I have tested it on an electric t-case driveline, and it is shift perfectly.
I have two for sale right now.
Price: $75shipped
(The part is the black adapter that the linkage is attached to):
Old 03-23-2010
You need a manual t-case. This bracket just gives you the provisions to bolt the manual t-case linkage onto your stock tailhousing.
Check out TrePaul's thread. We built his together and then i built these as an offering to you offroad guys who want to swap in a manual tcase but can't because they don't have the tailhousing:
https://www.ranger-forums.com/f42/tr...thread-103984/
Old 03-23-2010
01RangerEdge's Avatar
Scrambles the DeathDealer
Will you continue to make these? It may be awhile before I get my manual t-case.
Old 03-23-2010
very smart idea grant
Old 03-23-2010
Nothing planned yet. They were a lot more labor intensive than i thought...i'm getting old and can't crawl under trucks and stuff.
in otherwords: Probably not, I'd get it nao if i were you, lol.
Thanks Downey.
Old 03-23-2010
****** it up guys! These are awesome. Awesome alternative to those not wanting to fork out $223 for the right tailhousing on the SOHC motors... Meaning 01+
Old 03-23-2010
Ugh I need money, time to sell unnecessary organs
Old 03-23-2010
TrePaul speaks the truth!! haha, Thanks man.
And sorry i spammed your thread, but i just had to.
Old 03-23-2010
That's actually a 1354 manual shift front half, Grant... Not electric...But yes, it does shift very smoothly!
Old 03-23-2010
Yup. i meant it as it was on an original electric drivetrain, but converted to a manual t-case. But yeah, what he said.
Old 03-24-2010
chevyslayer925's Avatar
so is this needed for the 5r55e or is this need for a manual trans. my truck is basically an 01 minus the motor.
Old 03-24-2010
No, it should work fine in the automatic...let me confirm this with TrePaul or my brother though.
Old 03-24-2010
Scrambler82's Avatar
Old Guy User…
I’ll take one !
Does that include the Linkage and the Wood Piece ? LoL…
OK now to find the linkage !
Old 03-24-2010
These brackets are ONLY for 2001+ 4.0L SOHC motors. Since they're the only ones that didn't have the threaded bungs on the tailhousing, these brackets give us guys that option. All the automatic tranny tailhousings had it and the older M5OD-R1 had the bungs as well.
Old 03-24-2010
Originally Posted by Scrambler82
I’ll take one !
Any ranger I believe 88/9-97 had the option, 02-03 ranger, 90+ bronco II and explorer up til 94 had the linkage. I just pulled it the other day for $10. You'll need a big crescent wrench for the front bolt and a 9/16" for the back bolt after putting the case in 4lo. Be sure to grab the plastic round notched washer.
You want the linkage to be the kind that is straight on the outside piece that attaches to the case. If it has a bend in it, where it mounts to the case, it's 1350m linkage, not 1354m linkage. Hope that helps.
Old 03-24-2010
Old Guy User…
So what about the 3.0L 5-sp 2003s ?
Do I have the bung in place ?
Old 03-24-2010
I don't think you have the bungs. Since all the trucks had the same t-case bolted to the tailhousing, the bracket should bolt up. But i guess just crawel under your truck and see if you have two threaded bosses in the tailhousing
Old 03-24-2010
Old Guy User…
OK hold part please, I will get back to you asap.
Old 03-24-2010
i may just buy one on the outside chance anyway.
Old 03-24-2010
I'm pretty sure he does. The 3.0 OHV was an older motor and was offered the tailhousing with the bungs in it... I could be mistaken though.
Old 03-24-2010
Jason, crawl under your truck, I'm 99% sure you have the right tailhousing for the swap since your speed is measured at the rear end abs sensor, not the the tailhousing like the 2001+ guys.
Old 03-24-2010
yea im gonna look here in a second
Old 03-24-2010
Old Guy User…
I just crawled under my 2003, 3.0L, 5 sp and there is no extra holes in the tail housing near the T/C.
Old 03-24-2010
Hmm, looks like you need a bracket then sandy! Jason, i'm still positive you have the bosses on your tailhousing...
Old 03-24-2010
just looked i do infact on the driverside of the tail housing have the two bungs.
Quick Reply: For Sale: Manual t-case linkage adapter--OR
