Another great "tool", Norton Rapid Strip
Old 09-09-2009
redranger4.0's Avatar
Found these from a member on another board. They are great for taking paint off, as well as light rust and dirt. I found they work best when you use a wire wheel real quick to get anything loose and the larger stuff off then go over and finish with one of these. Im cleaning my frame since I have the body off. They have a standard 5/8" arbor. So they fit on just about every 4.5" grinder.
Old 09-09-2009
Ill get some pictures of them in action tomorrow.
Old 09-09-2009
Lazler's Avatar
Senior Member
I'm using the same thing on my trailer for taking it down to bare metal for re-painting
Old 09-09-2009
where did you find that at? looks like it would work well in several situations. I just bought a few wire wheels for taking off the powder coat on my cragers. These may have worked better.
Old 09-09-2009
Home Depot carries Norton Products. Thats where I get mine from.
I grabbed a comparison picture between just a wire wheel and wire wheel then rapid strip.
The left side is just a wire wheel. The right side is the same amount of time with a wire wheel then about a minute of using the rapid strip disk.
Old 09-09-2009
chainfire's Avatar
We have a bunch of different ones at work. They are great for giving a nice clean appearance.
Old 09-09-2009
Smakes's Avatar
dam that cleaned your frame good!
Old 09-09-2009
Yep, a little Brake parts cleaner on a rag, then paint an it looks really good. I have portion of the frame done and it looks really good.
Old 09-09-2009
FMD's Avatar
FMD
FMD is offline
Im impressed. Now when you paint it, dont cheat yourself, get the best primer/paint you can afford.
Old 09-09-2009
WowMike2001's Avatar
Por15 all the way!!! Do it right, and you wont have to worry about it - after you por15, let it set for a few days - clean it with a powerwasher, wait till dry, and undercoat it with some of the nappa rubberized spray - keeps that salt away!
brian90744
04-06-2012 06:40 AM
rangerstepside
Meets, Greets, & Events
02-19-2011 10:02 PM
Scrambler82
05-07-2010 05:27 PM
HighRollerII
19
05-11-2007 07:15 PM
Wowak
20
12-22-2004 01:39 PM
Quick Reply: Another great "tool", Norton Rapid Strip
