Power Window/Lock conversion
Old 01-22-2006
Well I have removed all this stuff to sell to a member on here, and I want to make sure I've got what will be needed for Power Windows, Power locks, and keyless entry.
The parts are coming out of a 2001 XLT 4x4 and going into a 2003 XLT.
-Door panels
-Door handles and switches
-lock solenoids
-window motors
-door wire harnesses (connect from windows/locks/mirrors to under dash wire harness)
-CSM
-GEM
Is there anything else needed for the conversion? Thanks!
Old 01-22-2006
whats csm and gem?
Old 01-22-2006
central security module and i'm not positive on the gem... some sort of electronics management module i think
Old 01-22-2006
04lvl2's Avatar
GEM is short for general electronics module.
Old 01-22-2006
-Door panels
-lock solenoids
-window motors
-CSM
-GEM
There are also two relays associated with the power windows located in Auxiliary Relay Box #1. It is under the dash just to the right of the steering column and might be something like 6" long and 1 1/2" square but that's just a rough guess. It would probably be good to include the whole ARB1 in case it doesn't exist on the other truck.
Old 01-22-2006
Chucks05EDGE's Avatar
What would I need to install power windows and door locks on my truck then? I don't have a GEM...
Old 01-22-2006
fuze's Avatar
At least for the years I am familiar with (97-01) the power windows and locks are mostly independent of everything else...except for the driver side auto down feature which the GEM helps out with. If you just want functional locks and windows, you can always make them work with just the switches, actuators, and a few relays. Keyless entry will complicate things a little more. I'm in the process of adding power windows, locks and keyless entry to my 97. It's pretty straight forward. I just needed new switch bezels for the doors, window motors/regulators, lock actuators, and the alarm/keyless entry module out of an explorer. I am already switching out the GEM and relay boxes for other reasons.
You have a GEM...it just may need to be swapped for one from a truck with those features. I don't know for sure how things may be different on an 05, but some switches and relays will always make it work.
Old 01-22-2006
Do you have a picture of what that might look like?
whippersnapper02
41
04-24-2021 03:31 PM
FULLSCALE
03-15-2009 07:20 PM
ac0413
03-01-2009 03:53 PM
robert99ranger
05-24-2008 07:32 PM
03DualSport
12-11-2006 04:36 PM
Quick Reply: Power Window/Lock conversion
