Skidplate for Superlifted Trucks (IFS)
Old 10-03-2008
RangerNVS's Avatar
Well I finally got started on my skidplate for my truck. Superlift wants
200 and some change (more than I have in my couch) for their pip-sqeak skidplate that probabley would take hit to save it's life from a rock. So I figured I would make my own. I know the one that comes with the offroad package is a joke also.
I went down to my local steel supplier and picked up a piece 25x18 1/4 plate steel. Heavy and really stout stuff. Anyway I worked on it a bit tonight. I wanted maximum (sp?) coverage for the two front crossmembers, and that is a problem when it comes to the hardware being in the way. Here's what I got done tonight:
Here's what I started with, also that's a 70 degree bend that's tapered:
Side view:
Here's a template I made:
Where it's gonna mount:
Part of it cut out:
Both sides cut, need some fine trimming and needs to be cleaned and the rough edge's cleaned up:
OK here's the finished product, I'll post more in the snap-shots:
Check out snapshots for more pics
I'll update with more pics when I get more of it done
Old 10-03-2008
Ray_Welder's Avatar
Looks good!
Old 10-03-2008
redranger_02's Avatar
looks good
Old 10-03-2008
nice man..guess your making one to protect the front diff?
Heres mine i made out of 1/8in aluminum to protect the radiator..old pics i had before it was mounted....
I tweaked it a little more before i mounted it.
Old 10-04-2008
NICE!!! I've been tossing this idea ever since i install the superlift. To mount, I was going to weld little 1x1 pieces of angle iron to the SL crossmembers, then a hole on the other sideof the angle. Use that as a mounting point for the plate. Probably weld some carriage bolts to the skid, and grind the heads off, fill where needed. or hell....cut the head off the carriage bolt and weld the rest to the skid. Thanks for more ideas guys!!
Clinton
03-22-2012 11:15 AM
djboldt@hughes.net
11-15-2010 04:25 PM
TColeman77
03-26-2010 03:29 AM
00Ranger4digbeast
37
09-12-2009 04:15 PM
xp1ik99
OLD - Ranger Based Vehicles
06-28-2009 11:52 AM
Quick Reply: Skidplate for Superlifted Trucks (IFS)
