Syphoning gas?
Old Aug 13, 2006
l2en's Avatar
Syphoning gas?
Maybe this is in the "How to break in my ranger" scheme of things but....
I've got 3/4 of a tank of gas in my burned out truck. Are there any one way gates or anti syphon devices in the fill tube? I just wanna gt that out of there w/o messing anything up. I'm sure I can sell the gas tank so I'm not keen on cutting into it. I'd have to remove the skid plate anyway. Any hints/experiences on this matter? PM me if there's some kind of secret trick.
Old Aug 13, 2006
5speedin2.3's Avatar
goto like.. autozone and get a syphoning thing.. it has a pump i think..
when i worked at a truckstop speedway we had em.
ORR... you can get a piece of hose.. and suck on it till you get gas in the end (make sure you dont get it in your mouth..) then put a can under it and let it go..
Old Aug 13, 2006
l2en's Avatar
That's what I was going to do. But I know alot of newer vehicles have anti-syphon devices on them preventing the hose from being inserted far enough to get to the tank.
Old Aug 13, 2006
drill bit to the bottom of the gas tank...
Old Aug 13, 2006
disconect the line in the engine bay or at the fuel filter. find the fuel pump wiring harness jump the main 12+ to keep the pump running and drain that sucker, thats what i did to my escort
Old Aug 13, 2006
good posting! since it is being totaled......a 1/2 in drill bit to the lowest part of the tank would work!
Old Aug 13, 2006
SouthernMudSlinger's Avatar
I think ya'll are missing something.
I just wanna get that out of there w/o messing anything up. I'm sure I can sell the gas tank so I'm not keen on cutting into it.
Old Aug 13, 2006
my post did not.. its acully explained how to do it with out hurting anything
Old Aug 13, 2006
and i agreed with him, but i also added a way to do it if he don't buy the truck back!
Old Aug 13, 2006
CAW's Avatar
CAW
If you can't syphon it normally, see if you can disconnect hose where you fill the tank. That might bypass an obstruction if there are any. Or if you could remove the fuel pump to gain access but i don't know if that would be practical/possible to do.
Old Aug 13, 2006
why use the pump to your advantage
Old Aug 13, 2006
i would try the fuel pump idea. but its going to be a PITA to get power to it.. being that the wires are all fuxed.
Old Aug 13, 2006
l2en's Avatar
lol, that is a good idea stone. I'll have to look into it tomorrow, shouldn't be too bad
from the firewall back, she's perfect
Old Aug 13, 2006
04lvl2's Avatar
If you can find the fuel pump fuse then just supply voltage from a battery or another vehicle via a jumper wire to the feed side of the fuse. That will make it easier then trying to find the wiring for the pump.
Old Aug 13, 2006
l2en's Avatar
hmmm, i'd have to look that up. anyone know off the top of their heads for an '03?
Old Aug 13, 2006
you could remove the filler neck and get the fuel out useing a hand pump since that should be past any check valve that may exist
Old Aug 13, 2006
TommyC's Avatar
Not to hijack the thread but....
At work we have an abandoned car that has been sitting there for over 7 months. I've called the cops and it isn't a stolen car and they have no interest in checking it out. If we want to get rid of it we have to pay a tow company, and since we have so many parking spaces it just sits there.
Anyways, does anyone know how I can force open the gas door (it has the release switch by the driver seat)?
Old Aug 13, 2006
RockysFord's Avatar
^^ pull on it? My probe had a release handle and sometimes it didnt work, you just have to stick a key in the side and pry...
Anyways, i think there is a 1 way valve in it, on my 03 there is anyways....It was cake to drop the tank though....just not as easy putting it back...
I would just try to stick a hose in there 1st and see if it goes in, if not do what zach said...
Rocky
Old Aug 13, 2006
l2en's Avatar
Yeah i didn't have time to try it today. I'll work on it once the optima forensic team leaves lol.
Old Aug 13, 2006
CAW's Avatar
CAW
Not to change the subject, but I'll be curious to hear exactly what went wrong with your truck when you find out. I think i may have one of the same accessorys as you that might be in question. I'm probably just being paranoid though.
Old Aug 13, 2006
l2en's Avatar
I'll be making a new thread tomorrow on the topic.
Old Aug 14, 2006
you can get to the wire on the frame dingo
njdriver04
Jul 30, 2019 10:37 AM
Smith13
Dec 29, 2014 02:26 PM
CadiLLacPimPin
Jan 23, 2007 07:57 PM
RangerEdge17
26
Sep 19, 2006 02:03 PM
Bent XLT
Auto Detailing 101
16
Jun 16, 2004 12:59 AM
