Slip bump in the driveshaft or trans?
Old 01-02-2007
well i know its been discussed before but when i come to a stop waiting at a light and then take off again feels like something slips then i get a bump in the drive train.
Only thing I'm wondering is if it is a trans problem or the slip yoke on the drive shaft.
wouldnt surprise me one bit if it is the trans but since this new drive shaft that is when i have noticed all the issues.
Any input? Does it all the time, unless i accelerate at an extremely slow rate.
Old 01-02-2007
It's usually the slip yoke splines.
Old 01-02-2007
Did i read that you greased yours before bob?
Old 01-02-2007
ahhh, the call of the slip yoke
Old 01-02-2007
I did regrease the slip yoke on my Trailhead (2WD) but it only helped for about 2 months. Ford sells a special PTFE grease for the slip yoke and that's what I used ($25/can!). When my LII started doing it, I slapped on a set of JD's and it has never done it since.
2WD is easy because the slip yoke just slides out of the trans tailhousing. The 4x4 yoke is more of a hassle. It's in the main driveshaft and you need to pull the accordion boot to grease it. From the factory, the boot is held on by special crimped clamps that take a special tool to set them.
Old 01-02-2007
I think my first attempt will be to complain to the company that made my driveshaft...
Maybe they could put some type of grease fitting in it.
I guess that is where i will start, was just worried that it could be tranny.
Thanks!
Old 01-02-2007
graniteguy's Avatar
my mustang does that when I'm at the track.
Old 01-02-2007
my truck does that every now and again........i think it is my tranny starting on its last leg...
Old 01-02-2007
rngprerunner's Avatar
My truck does that EXACT same thing Zach. It is rediculous and I have been chasing it for years.
The only time I have ever gotten it to go away was when I greased the slip yolk and changed u-joints... so I guess that is what it is.. though I also suspect the trans could be the problem too..
Just felt like adding to the topic... not that it helps.. lol..
Old 01-02-2007
i can tell we are all hoping its not the trans. lol
Old 01-02-2007
jrpro130's Avatar
Just pray it's not the trans
Old 01-02-2007
04lvl2's Avatar
ITS NOT THE TRANS lol, grease the slip yoke man and check your Ujoints for binding
Old 01-02-2007
2002ranger's Avatar
mine did this for a while, especially when it was cold, my tranny fluid was low and would contract in the cold..after the tranny fluid was topped off i started getting a really bad squeek or screech..ended up having to replace my torque converter.
Old 01-03-2007
JoshK's Avatar
Just turn up the radio and it will all be good.
Old 01-03-2007
haha hey im just taking the lazy route right now, see what input everyone has
99offroadrngr
OLD - Engine & Drivetrain
05-13-2014 05:34 PM
StxDangerRanger
eBay & Craigslist Finds
05-16-2012 03:20 PM
wellcom2knoxvile
08-23-2010 07:17 AM
zabeard
20
09-02-2007 07:31 PM
neocon
02-19-2006 10:17 PM
Quick Reply: Slip bump in the driveshaft or trans?
