fuel pressure doesnt hold when key is off
Old Aug 31, 2008
06fx4 L2's Avatar
this truck takes a long time to start.. it cranks for a long time then sputters some and then finally starts and runs fine. after checking the fuel pressure i found that it drops to 0 almost as soon as the key is turned off. i know there is a check valve somewhere in the fuel system to keep this from happening. does anyone know if i can get it sperate from the fuel pump or does it come with it?? i asked the ford dealer around here and they couldnt figure it out. maybe i should just call back and talk to another parts guy
Old Aug 31, 2008
IN2 FX4's Avatar
You have to buy a new fuel pump. The check valve does not come separately.
Old Aug 31, 2008
Shmokinjoe's Avatar
X2
Old Aug 31, 2008
XeRo's Avatar
Get some seafoam, and put it in the gas tank and change the fuel filter. Also, you might have a wiring problem, check the voltage at the pump when cranking and priming/starting.
Old Aug 31, 2008
06fx4 L2's Avatar
o thank god a real answer!!! thanks smokinjoe and in2 fx4!!! did you guys have this problem or is it second hand experience?
and xero it has good voltage and pressure while running it just doesnt hold pressure when off
Old Aug 31, 2008
Blhde's Avatar
Have you tried cycling the key on waiting say 15 seconds then cranking?
Are you past your warranty?
Old Aug 31, 2008
06fx4 L2's Avatar
yes cycling the key helps but it still has a problem. well i am outta factory but i still have an extended warentee but this is a friends 2001 ranger with over 100k on it not mine.
Old Sep 1, 2008
Earl43P's Avatar
A leaking fuel filter will make it do that too.
I agree it's probably the check valve (part of the fuel pump), but look for seepage around the fuel filter lines. Driver side inner frame rail.
Old Sep 1, 2008
06fx4 L2's Avatar
i replaced the fuel filter first thinking that the check valve was in it due to the 2 in 1 out arrangement of the filter so i checked for leaks at that time and it was ok
Old Sep 1, 2008
Blhde's Avatar
Well trucks got a 100k on it i say a fuel pump can fall into a needed part for maintenance reasons.
However im not 100 % sure the pump has the check valve. It maybe in the regulator.
Does the truck have a CEL or any stored codes?
Old Sep 2, 2008
06fx4 L2's Avatar
no check engine light and i dont have a code reader that i can take home with me. ima just do the fuel pump..lol and tell him that it MAY fix it
Old Sep 2, 2008
Blhde's Avatar
Make sure and grab a new strainer screen while your in there.
GL
Old Sep 3, 2008
06fx4 L2's Avatar
hmm doesnt come with it? i will do that!
Old Sep 5, 2008
Blhde's Avatar
When I got a new assembly (pump reg and fuel sender) it did not come with the strainer. Granted this was from Advanced. YMMV
Check the parts before you leave to make sure you have one.
jdbs3
Aug 2, 2018 12:47 PM
thalightguy
Sep 7, 2012 04:47 PM
Rooks
Dec 28, 2011 11:52 AM
fedupdon
Jan 31, 2011 06:04 AM
Ranger_mayne
Oct 25, 2006 09:47 PM
