Here is why EDGE plus wheels don't fit 2003 and newer 4x4
Old Jun 1, 2005
Ranger1's Avatar
Look at the wheel to caliper clearance on my stock 16 inch wheel
Look at the wheel to caliper clearance on Johns 15x7 edge plus wheel, there is not clearance
Look at the clearance on my american eagle alloy 15x8 wheel with about 3 inches of backspaceing some but not alot of clearance
Old Jun 1, 2005
aha! it all makes sense now i noticed this earlier today when i was cleaning my stock rims sans tires for storage
Old Jun 1, 2005
wow....
Old Jun 1, 2005
Bigwill41's Avatar
I think I better go look at mine...
Old Jun 1, 2005
FoMoCoFiddy's Avatar
My edge had edge plus wheels. And it was a 03?
Old Jun 1, 2005
pacodiablo's Avatar
It was 2WD. 4WDs have the clearance problems.
Old Jun 1, 2005
01xltranger4x4's Avatar
Wow, 2001 xlt isint a problem is it? I had stock 16x7 teradrops, and now have 15x8 eagles.....i dont think there is a clearance issue, but i could be wrong.
Old Jun 1, 2005
um im confused? are you talking about after the larger rotor upgrade for made? if you are its not all 03s as mine has the smaller rotors. anything after march 2003 the rotors are an inch bigger.
i have edge plus wheels.
Old Jun 1, 2005
Draimen's Avatar
Aren't the wheels you have the same that come on xlt's and fx4's?
I think hes talking about this style Name:  Muddy.jpg
Old Jun 1, 2005
Mnemonic's Avatar
Not according to your avatar you don't.
Old Jun 1, 2005
oh ok well musta got confused then.
Old Jun 1, 2005
edge plus wheels are the old 5 split spoke 15" zach
Old Jun 2, 2005
Sonic04Edge's Avatar
Partly correct. I have a edge plus wheels and they are the 16in teardrops
Old Jun 2, 2005
Ranger1's Avatar
pre 2003 4x4 are fine, all 2WD are fine, aftermarket wheels are fine(your 15x8 eagles are fine), stock 16 inch wheels are not a problem,
stock 15 inch wheels on a 2003 or later 4x4 is bad
Old Jun 2, 2005
Ranger1's Avatar
Also stock FX4 Level 2 alcoa wheels are fine, they are just like aftermarket wheels, they have a different tapper and backspacing.
Old Jun 2, 2005
Ranger1's Avatar
Here let me put it this way
Wheels that will fit 2003 and later 4x4:
Stock 16 inch
Stock FX4 level 2
most any aftermarket wheel with about 3 inches of backspacing
Wheels that will fit pre 2003 4x4 and any year 2WD:
any 5 on 4.5 wheel
Old Jun 2, 2005
SoundPer4mance's Avatar
john and i have already had a lengthy discussion on this matter....
factory 15s will NOT FIT 2003 and up 4x4 ONLY
that means 2002 and back 4x4 will work
and all 2wd will word.
the rotors for the 4wd were upgraded in 2003
Old Jun 2, 2005
LILBLUE04FX4L2's Avatar
wow Ben your Eagle Alloys don't have a lot of space either
I guess that could be good too, even less room for stuff to get in there
I always worry about small rocks getting between the caliper and rim
unless they are the factory Alcoas
Old Jun 2, 2005
are the alcoas still 15s on 03 and up?? if so i stand corrected
Old Jun 2, 2005
winks's Avatar
Good job clearing that up Ben. Didn't realize thre was such a small amount of clearance on my alloys.
Old Jun 2, 2005
yeppers!
Old Jun 2, 2005
Ranger1's Avatar
I would asume you have about the same clearance with your alcoas as I do with by eagle alloys.
Old Jun 2, 2005
just went and checked - about 3/8 of an inch at most
Old Jun 2, 2005
Ranger1's Avatar
Look like this ?
Old Jun 2, 2005
karrbass4life's Avatar
G-DAMN!!! I got stock Edge 16's so im in the clear right?
