General Technical & Electrical General technical and electrical discussion for the Ford Ranger that does not fit in any other sub-forum.
Can't drive my truck! Need help ASAP with Electrical
Old Apr 30, 2010
Police Interceptor's Avatar
Hopefully i can get some help here
I drive a 2001 3.0 v6 4x4 AT
Alright so i went to start my truck this morning and it started. I let it warm up for about 30 seconds then it started chugging so i let it run a little longer and it was just getting worse. Then my lights started dimming and the radio shut off so i shut the truck off.
No other cars at the house to jump it so i went to school came back had brother in law jump it and follow me to autozone.
They tested my battery and he said the alternator wasn't doing anything. Drive back home (died 3 times) went and got an alternator off of an explorer (130 amp) Guy guaranteed it to work or he had another one he would give me.
Went home put it in and same problem. I tested the battery and it is only getting 12.28 volts. Not enough, so i wiggled the plugs and wires to see if they were loose and no luck nothing jumped up or changed it just slowly dropped.
Now i have no ride!!! Need your guys help
I had both alternators tested, (old and new) Both Passed. i bought a new battery and had the starter tested and it's good..
I don't know what too do next
Old Apr 30, 2010
I've had this happen before. Took the battery and alternator to Autozone to be tested. Both passed. A few days later it happened again. Took it back and it was the alternator. How old was the new alt that you got off the Expo?
Old Apr 30, 2010
I had them test both my alternators, my old one and new and they both passed and idk how old it is
Old Apr 30, 2010
Try another alternator. It's worth a shot.
Old Apr 30, 2010
Blhde's Avatar
Make sure the fuses for the alt is good. Also the wires that plug in the back.
It needs input current to create output.
Old Apr 30, 2010
djfllmn's Avatar
Former Ford Parts Monkey
id say just pay the extra money and buy a brand new one that should solve the problem
Old Apr 30, 2010
cheese_man's Avatar
that`s not the problem
pull the battery out and check wiring harness that is connected to the inner driver`s side metal fender
friction has rubbed off the wiring insulation and the battery charge wire has grounded out to the metal fender
you will have to remove some of the electrical tape
i had the same problem in the winter time ( both alternator`s checked out fine for charging )
Downey
Dec 7, 2015 05:57 AM
notsob2012
Feb 26, 2012 04:13 PM
Seb_L
17
May 1, 2010 12:42 AM
rybread5520
Jan 2, 2009 09:41 PM
n3elz
23
Sep 11, 2005 11:38 AM
