Need advice.
Need advice.
Hopefully I get a little more input this time around.
I posted the problem almost a year ago and got zero response, still having trans glitches and am looking for a little advice.
The problem I posted a while back :
This seems to ONLY happen in the winter, it has only maybe once done it this spring/summer/fall BUT it does shift hard/shudder between 1st and 2nd 85% of the time. My problem is that the problem is intermittent, I still have a powertrain warranty and want to get it fixed before it goes out and/or my warranty expires but I am afraid they will not be able to recreate the problem and just take my money or even if they do find it shifting hard between 1 and 2 they will just shrug it off. If they look at it and find nothing its $150 to me which I really dont want to spend ATM and the problem is still there, if they do fix it, its only $100 and my truck is fixed anybody have any suggestions? It is going in regardless to have the pinion seal replaced, just not sure I want to fork up more dough to have them "look" at my trans. and find nothing.
Ive got an '04 4.0 xlt 4x4 with an auto trans. 48K on the clock. Just the other day I was cruising between 50-60mph and I heard a loud thump and my truck kind of shook like I ran something over....looked in the mirror,didnt see anything so I figured it was a pothole. Couple miles later it happened again and continued happening anywhere from every 2-5 miles. WTF, transmission shifts fine everywhere, no noise, vibrations or anything and it only happens between 50-65mph. I went home, checked the trans fluid it was just above the bottom of the hatching so I added a little, right around the top of the hatch now and it seems to be doing it less (I think) there seems to be no pattern to it or related to anything I am doing with the brakes or throttle, it happens less now but did it once on my way to work this AM.
Bummer, not the answer I was looking for warranty doesn't cover a flush. Do the symptoms sound like dirty/old fluid and filter or is that just a temporary fix to cover up the real problem? I don't want to flush and fill it to prolong its life till just outside of the warranty then have it shlt on me.
Well, I brought my truck in to have the pinion and diff cover seals replaced and told them to take it for a spin just to see if they though something was wrong with the transmission once they got it done. Sure enough they felt the same thing I did and are taking it apart today. It better be covered by the warranty....hopefully a new transmission? Is it common to have transmission problems around 60k?
Hopefully they will be calling me today with an update and I will post once I get more info. They where originally trying to sell me into a flush and filter but wanted $150+ for it. I didn't want to do that to "relieve" the problem for a while only to have my tranny go after the warranty expired.
But yeah the jolt on the highway was pretty violent, felt like the brakes just lock up quick then let go and the shudder between 2nd and 3rd was pretty gross too.
Just talked to the Stealership and they said they had to replace a solenoid in the trans...problem solved. Ill be glad to have my truck back this Taurus sucks. They also said I should think about front brakes, if I want they can do it while its in there. $300 and some change but they have a $25 mail in rebate. Ummm no Ill just do that myself thanks.
I am pretty sure it was not the OD solenoid, last winter when it was a recurring problem (mainly the first time it happend and scared the sh*t outta me) I figured maybe there was a problem with the OD because it would only happen around 55-65 mph so I tried turning the OD off and it continued to happen at exactly the same speed (range).
Safe Mode
Something like this occurred on my 99 Ranger. The OD drive solenoid had failed and I had to run in Non-OD mode. The transmission would sometimes go into safe mode and hard shift which gave the hard impact sensation that was described. This would occur in OD or Non-OD mode but mostly in OD mode. I had the transmission rebuilt and was told 2nd gear was basically gone and the OD solenoid was not working.
rdelp68
08-23-2011 07:48 PM
